mnboarder 10+ year member
I'm ordering all of my parts for my first setup and my sub i ordered turned out to be on backorder so I'm suppose to substitute it. I ordered a Kicker VCVR122 enclosed sub. I have a Kicker ZX500.1 Amp coming and I need to find a enclosed sub to match it. I'm looking for a single 12" sub that would match the RMS of the amp.
Here are the amp specs
Kicker ZX500.1-
# ZX Series Class D Monoblock Car Amplifier
# RMS Power Rating (14.4V):
* 4 ohms: 250 watts x 1 chan.
* 2 ohms: 500 watts x 1 chan.
# High efficiency MOSFET power supply
# LED power and protection indicators
# Remote bass level input (Kicker 10ZXRC remote level control sold separately)
# Tuned Bass EQ (0-18 dB bass boost at 40 Hz)
# Preamp RCA outputs
# Muting circuit cancels out unwanted noise
# Boost, gain, and crossover frequencies are top-mounted for easy access
# Balanced differential inputs for noise elimination and factory-radio compatibility
# 3 Automatic turn-on modes (remote, DC offset, signal sense)
# Optional edgy vinyl skins for personalizing heat sinks available
# Optional Kicker 08ZXEC endcaps are available for all ZX amplifier models
# High-density convection heat sink for extreme heat dissipation
# Gold-plated RCA level inputs
# Gold-plated screw terminals
# Input sensitivity:
* Low level: 125mV-5V
* High level: 250mV-10V
# Variable low-pass filter (50-200 Hz, 24 dB/octave)
# High-pass subsonic filter (24 dB at 25 Hz)
# CEA-2006 compliant amplifier
# Frequency response: 25-200 Hz
# Dimensions: 12"L x 9-5/8"W x 2-1/8"H
# Actual power exceeds rated power, documented inside each carton
# 4-gauge power and ground leads recommended. Contact us for information regarding a discount on a select amplifier kit when purchased together.
I would prefer a Kicker sub but whatever works best is fine with me.
Any help is greatly appreciated!
Thanks!
Kicker ZX500.1-
Thanks!
