yeah,just buy a 3.5mm headphone to RCA adapter and run it to your AC 4.1. you might need a line driver to boost the signal volts,but the AC 4.1 might have one built in.Just seen an iPad installed in a Tacoma. My question is can I use the iPod rca method and hook it into say an audio control 4.1 and then feed it to my amp? Any suggestions?
this.. DON'T CHEAP ON THE 3.5MM-RCA! it will make or break youyeah,just buy a 3.5mm headphone to RCA adapter and run it to your AC 4.1. you might need a line driver to boost the signal volts,but the AC 4.1 might have one built in.
this is 100000% truethis.. DON'T CHEAP ON THE 3.5MM-RCA! it will make or break you
