what size slot?
  • 2
robertoyoung08
bay area, ca
have another thread on figuring out aeros. fasfocus helped but now im getting people saying its not right.
until the aeros come together i will have a slot port.
need 2.5cubes at 35hz
30w x 14h x 15d gives me about 2.5 after sub displacement
what lengths and height should the slot be?
(does the enitre slot port area also count as displacement? my above net volume is assuming its a sealed. idk if the port would also take away?)
thanks again guys. this site has been real helpful since i found it. hope i can help some of you guys out whenever i can in return!
going the re way for now since i dont have any responses yet.
do these re calculations look right?
thanks again.
what lengths and height should the slot be? depends on whic hway its facing. back up et cetera. subtract 1.5 from that sides length.you'll want 25-40 sq in of port area. depending on the sub your using. example with that box if you were going to have port facing rear. the port would be 12.5 tall x 2~3.5wide.the length will then vary based on whaat size the port is.
yes the ports displacement must also be taken into account. if youd like some more help with this id be more than glad to help you via pm. or i can do you a design with 3D sketch for a small fee.
thanks again guys. this site has been real helpful since i found it. hope i can help some of you guys out whenever i can in return!some of us try to help whenever we can //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif glad to hear you plan to be a positive contributor
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
Tesla beat Edison. Why do you think we transmit high voltage ac? Cars are low voltage dc, which is absolute worst as far as efficiency goes, but...
61
It's a little overkill but hey... https://blackbrickaudio.com/collections/30-000w-amplifiers
robertoyoung08
robertoyoung08
bay area, ca
marcotheclepto
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
