bustaplz 10+ year member
Pissing off the world.
I just ordered these components to build a custom center channel for my Logitech Z-5500 system that I run on my computer.
http://www.parts-express.com/pe/pshowdetl.cfm?&Partnumber=264-804
http://www.parts-express.com/pe/pshowdetl.cfm?&Partnumber=295-302 x2
http://www.parts-express.com/pe/pshowdetl.cfm?&Partnumber=260-144
In the future I will probably upgrade to a decent reciever and some different surround speakers. I replaced the fronts with a pair of Sony bookshelf speakers that I've had around for a while and liked the sound better so I'm going to upgrade the center channel. I'm probably going to build a new subwoofer box when I build this center channel to use a spare RE SR10D4 that I have.
This is a sketchup of the enclosure I have planned. It should be about .4 cubic feet tuned to 55hz after displacement. I used WINISD to do the calculations as I've never build a ported box for anything but subwoofers, but the response curve looked good for the woofers. It will act as a monitor stand also, that is why it is taller in the front, to fit the 5.25" woofers but keep my monitor at eye level. Anyone see any problems with my little plan? The center channel of the amp is rated at I think 69W@8ohms RMS.
