Wall help for someone who dosent know stuffz about walls...4 15s...FYI...WTF
Which Box Design?
  • Total voters
bamaboy
War Eagle!!!
need some opinions for a wall im about to start, going for loud daily demo material stuffs, not too concerned on meter, but it needs to be able to tag some numbers;)
4 RF T2 15s and a t40001bd
04 Explorer
originally 18.5 cubes gross(~16 net)
200sq" port tuned to 37hz
a lil too high for my liking so gonna lower it to 32-34hz
was measuring and im gonna end up doing 2 separate boxes because it would be **** near imposibe to fit a big one through the back hatch, probably 4 different chambers, so 4 ports, maybe 2 and 2
gonna be riding with the seat up to, so the bottom half of the box might be blocked by them, shouldnt be a problem though
img 1
img 2
gonna use 45s and such in corners, what other would you reccommend?
dude its an explorer i have seen many guys do it under the window line and put up some high numbers. your from alabama so have u heard of heath jordan, out of chattanooga he had a 95 to 98 explorer had i think 3 immortal 12's pulling mid 50's easy. last i had heard he done a 54 with one 15 i think. u have to do a lot of building if u wanna go for spl. now i am not knocking walls and such but i think walls should be used if u are running a butt load of power. plus if this is your daily driver i would give the box under the window line a try first if u already hasn't. subs up port back using aero's would be great so i have heard. but its up to you man i am not tryin to discourage u out of doing just saying that its going to take more than one build to get this thing right trust me i know i am on box number 7 i think in the last 3 months.
Ok then 11 cubes will be fine. Keep in mind the f/s of those woofers is about 28 hz, so you if you tune really high above that, the woofers can...
What would you recommend using for the roof then ? Should I do just the bpillar or the whole roof ?
850
If you order directly from taramps in brazil you can get a smart 3k for $259 shipped...
These are the tweeters in going to use in my truck. Beefy little guys just going by weight. Probably not the best for a car audio setup, but I'll...
63
8K
bamaboy
War Eagle!!!
bamaboy
Auburn, Alabama
basshedz06
chipss36
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
