RF Power 1000 and RE Speakers
  • 1
JoeSmith502
Beware of Dog!
585
South
OK, here is the situation. I have a set of RE XXX comps that are 2 ohm and a RF Power 1000 amp. The RF amp is rated 100 x 4 @ 2 and the sub channel is either 300 x1 @ 4, 600 x 1 @ 2 or 800 x 1 @ 1. I already have two XXX 12's in the trunk so with the sub channel on the RF I was going to run some 8" in the cabin. I know you are supposed to keep all your subs the same but RE doesn't make a XXX 8" but I did find some RE Series 8" that are rated 175rms. Would it be ok to run these along with my other subs? They are D4 so I could either run 2 at 4ohm or 3 at 2.6ohm. I will also be using the RE 6x9 in the rear deck wired together to get them to 2 ohm and I am going to make a center channel too, so will adding the 8"s just be overkill? Thanks for your help!
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
5
470
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
366
That’s the little single 6.5 inch enclosure. The Savard did just as well as the RDS. These subs do well in ported or 6th orders but not as well...
12
755
JoeSmith502
Beware of Dog!
JoeSmith502
South
JoeSmith502
Brendon Jenness
    May 8, 2024
Doxquzme
    May 8, 2024
