Simple box with 1/2 MDF
Is 3/4" that expensive?
Its like 6 bucks for the small sheets
I thought the same thing. But then I thought back to high school when I was broke as hell. If I had some 1/2" around I might have used it then too. If you're buying a new sheet of wood just go for the 3/4" and spend a few extra bucks.
but then you also save some space with 1/2" on each side so he can have a smaller box. If it's that small of box, 1 brace, if any, are needed.
haha...with a 12x12x12 box im sure the 1/4" hes saving isnt gonna matter
maybe he drives a Yaris, or a smart car?//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Just one reason to, that and saving a few pounds. No reason to use thicker wood if the 1/2" won't flex! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Its going in the back of my Grand National. Weight isnt an issue, but I bought 1/2 a couple weeks ago without re-looking to see what size I needed. I might just use the 1/2 to build and amp rack and buy 3/4 for the box.
How would I brace it if I did use the 1/2?
thanks guys
thanks guys
There are a few ways to efficiently brace a box for less flex.
1. Dowells. Use dowell rods to make cross braces, glue each and screw each end with one screw. Use multiple dowells in multiple directions to make the most efficient bracing.
2. Strips of wood. The same way you would use dowells.
3. All-Thread. A piece of threaded steel rod that you would run through the box and use nuts and washers to control the flex.
Hope this sheds some light on your situation.
If he puts any of those in a 1/2" box ill just bust out laughing
//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif:laugh://content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif:laugh:
Can you imagine all-thread being used in a 1/2" box....that would be hilarious
It's a Volvo factory amp, so there's a custom wire harness between the head and amp.
6
990
I went with those simply because they fit, the cutout is round, and the hole will take a 6.5 coax. Cutting a square hole in a boat for a speaker...
21
5K
I think you're going to find this is true across the board. Technology has come so far at this point that even the absolute rock bottom unit that...
6
I would run a pair of 15s in an suv.. or run 4) 12s
24
3K
No Issues out of my CT Sounds amps..EQ, 6.5s. There is not one company out there that hast ever had a perfect QC run that I can think of.Hard to...
8
ledzeppac
ledzeppac
orange county, ca
mazdakid
Doxquzme
    May 10, 2024
3toneEYZ
    May 10, 2024
