is a 4" port enough for a 12" bm???
~Magick_Man~
bedford,Tx
i am building a box tomorrow and it turns out i have the room to make it a ported box so i want to go that route.
the box will house 2 12" si BM's
there is no good area to place 2 ports next to each other so i am planning on seperateing the 2 subs and each chamber will have a 4" pvc port
does this sound like it would work?
i will have some pictures of what i am trying to do in a little while
Thanks,
~Magick_Man~
here is the basic idea i have right now.
it might change a bit but that is pretty much it.
so if i dont make 2 seperate chambers will the subs really utilize the area in the middle?
Thanks,
~Magick_Man~
you need double that port area.
have fun trying to make it fit //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
i am using a port calculator and for 2 4" ports in a 2 cube box tuned to 34 it says they need to be 26.xx"
is that each?
if it is then that *****.
because i can fit in up to 14" long ports.
would i be better off with 2 3" instead of 1 4" ?
~Magick_Man~
did yo use those port tubes on NoLimits box?
no i used a mdf slot port on his.
i am trying to stay away from that on this box because i dont want to mess with angling the port like it is on your box.
and i have a ton of 4" pvc pipe so i might as well use some of it.
~Magick_Man~
um, what's the volume of the box (after displacement) and how long are the ports?
adding two ports like that (and keeping them the same length) is going to make the tuning A LOT higher (10hz +) possibly.
i dont have the exact number yet but i have about 2.2ish per driver after the port is taken out.
i was looking at a single 4" at 11.xx" long which would supposedly give me 34hz with a 2cube box
now i am looking at 2 10.12" long with 2cubes after displacement which should give me ~36hz
i will end up with as close to 2.0 per chamber after the port and sub is taken out.
~Magick_Man~
yeah, thats probably not going to work... the port calc is EACH port, so adding more is just making your problem worse
yeah i figured that.
i was using one at 11.xx long shooting for 34hz
now i am using 2 at 10.12 (i think) shooting for 36hz
~Magick_Man~
so i guess the real question is will 2 4" ports 10.14" long in a box 2.0 cubes after displacement give me a 36hz tuning?
i am judging this off the port calculator from carstereo.com
~Magick_Man~
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
981
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
663
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
825
798
Yup. That is the bread truck that Richard Clark built for MTX many years ago . 60 inch subwoofer. The problem was that the truck wasn’t...
14
~Magick_Man~
~Magick_Man~
bedford,Tx
~Magick_Man~
Brendon Jenness
    May 8, 2024
    May 8, 2024
