ford
jmp11687
Anyone ever take out any ford stock h.u.. They are *****es espically my focus. We needed "special tools".
Just incase anyone else is in the same situation just thought i'd let you know have a hanger handy. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
My 07 Focus was a simple install...replaced the factory crap with a Pioneer Navigation system the next day after buying it...//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Took about 30 minutes total...
lincoln navigators are infinitely hard
especially when the navigator is trashed (as in dirty) to ****, so all the bolts you have to undo in the console and dash are ****ing stuck because of grime
373
One fuse (the 300) goes close to the battery to protect the power wire...then close to the amp you'll add another fuse (whatever size the...
29
4K
It is in eBay. It is a bit more complicated. You clip off the gray blocks on your radio's harness and splice in the new harness by color matching...
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
174
jmp11687
jmp11687
Indiana, lowell
maldecido33
    Apr 26, 2024
    Apr 26, 2024
