97 Grand Cherokee. LOL. I'm on the fence myself about what to do for my next build. The one I liked with everything firing up I left out in the yard and the port fell apart (sono tube is great for box building but not waterproof!) and I'm leaning towards re-building that. You should get a peak @ 54-57hz depending on the day (cabin gain). Really that seems to be good sounding and most efficient use of space BUT if you care about being on a meter, one that ports out the side with subs up will be best (you angle it to fire port at the corner when burping to gain a little more).
Subs and port forward is absolute crap, subs and port back is crap, subs firing to either side and port up is pretty good (also efficient use of space). I know Jacob at Sundown has sub up port back in his jeep, but it is pulled quite a bit forward (seats laid down for this), and personally I haven't had much luck firing ports back (especially compared to into a corner or out the side).
SO I'd say subs up and port to the side IF you can get enough volume while keeping enough space in front of the port, if you need more space, settle for subs and port up which will sound nice. If you care about SPL numbers you MUST port out the side if you want to keep everything behind the back seats, in which case you'll need to sacrifice volume or use less cone area.
