Zapco 350.2 amp help
Adamblack
Picked up this amp the other day in good working order. I'd like to pair it with two twelves. I have a 2003 f250 crew cab pickup with a little room behind the back seat for a good size box. I don't know the difference between a 2ohm and a 4 ohm sub besides being able to wire it differently. I don't want anything from this amp besides pushing 2 12inch subs.
So. ... what do you guys recommend in subs? Thanks in advance...
That amp is not great for running subs, much better suited for powering a front stage.
With that said, if you are going to use that amp I would run a cheaper lower power set of 8" or 10" subs like Pioneer.
Amp Specs
Stereo, 4 ohms: 2 x 100 Watts
Stereo, 2 ohms: 2 x 175 Watts
Bridged, 4 ohms: 1 x 350 Watts
I've decided to run with a single Fosgate P3 shallow. I'm sure this amp will work for a little. Does anyone have any experience with the P3S 1x12 in the already made box?
Adamblack
Adamblack
Hanford,CA
Adamblack
