Zachfeen's 04 focus hatch build
stangman67
Seattle
Here we go again, this is my attempt at a loudish daily setup. I've been working on this for awhile, should be done by next weekend as long as my box panels get here from mike by the end of the week.
Already done- Run of pos/neg Knu 1/0
Big 3 done in knu 1/0
Deadened hatch
Jvc highs amp
peerless mids/dayton tweets/robot underground xovers
Substage
Solid f2500
4 sa-8's in 2.5 at 35hz
Cheap ebay agm until I can afford some xs batts
I know you all love guts so here ya go.
Pics of the car/wiring to come tomorrow
Cheapie sds 6.5's. This component setup was an experiment so see what kind of sound I could get for 100 bucks (amp/drivers/xovers) and I am extremely impressed with how it turned out. I will eventually put some ID ctx65's in, but these do the job for jow.
A alot //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif around 3k at .5 ohm (after I get the xs batts). For now I will have it tuned to put about 400 to each
can u get the sds to give any kind of mid bass? i kinda did the same thing, spent around $100 and they were cheap so it worked. i love my tweeters but those things have like 0 bass, but my install probably *****
Looks good, I sat in your car at the Lincoln City meca comp and it was loud with just 2 8's(I had the red Chevy with the Type R's) Good luck on the new build, looks loud.
Yup yup I remember you. This should be a bit louder //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif And cruzer, the midbass is decent but the simple fact is these drivers are not designed to work in an ib setup. They would work well in a small ported setup. For the price I cannot complain though.
We'll have to see if we can get some kind of meet/meter session going on up here in Wa, then you oregon guys can make the drive up. I'll be itching to meter when this is all in.
Wiring color code should be ISO, just like American radios. If you get your vehicle specific radio harness, it should have the same colors as that...
In that case, a mono amp will do just fine. You can always use the bass knob to blend the sub with the front stage. Using a mono also opens a...
I'll be making it some time in the next few weeks. But that's my next project. This car. It belongs to my brother. But I'm working on it...
98
Looks good so far. If you ever need more up front, Q-forms makes some kicks to fit that civic, we use them in my brother's with good results...
940
stangman67
stangman67
Seattle
stangman67
    May 12, 2024
Brendon Jenness
    May 11, 2024
