XXX enclosure build pics
jonesy
2.8 tuned @ 34hz 3/4" plexy soon to come..................will add more soon im a little drunk as of right now! Yeah i know the cell pics aren't the greatest
Love the brace cut-out. Kind of worried though. It's not as "open" as a lot of other window braces I've seen. I'm wondering if enough material is cut out to allow for unrestricted airflow inside the chamber.
than should be enough bracing i think all long areas on the enclosure are 1.5". but i might add another brace by the port attach to the L part of the port and run it up to the baffle! or would that be overkill lol, my thoughts are to have the plexy recessed into the side and have it screwed into the side and braces for a more rigid enclosure ill use some 2" screws:D The plexy window might be 16X16 but i have a 16 x 24 1/4 pc to play with, or i could do 2 16 x12 windows one on each side.........the woofer will be sub up port up hmmmmmmm
i might make the center of the E all the same length, and i will cut out more what design to cut out now......... any suggestions?
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
784
jonesy
jonesy
Castletion Ny
southpoleman69
    May 31, 2024
    May 24, 2024
