Xtracab pickup, is rear fill needed?
toneddie
Here is my set up. Alpine CDM-7874, Fosgate 250.2 bridged mono to JL Audio Stealthbox, Infinity Kappa 5 x 7 running off HU, factory tweets in upper door panel off HU.
I have two questions:
1. Should I install a mid-priced component set and add another amplifier then relocate the 5 x 7's to the rear factory locations?
OR
2. Should I add another amp for the Kappas' and the factory tweets and eliminate the rear fill stockers.
I like it loud and clean.
Any suggestions welcomed
David
toneddie-add another amp and
get a good set of componet speakers and wire them
to your new amp
move your 5x7 to the rear stock speaker location
( if they fit .) and wire the 5x7 also to the amp
i have an extended cab ranger, and i don't have any rear fill. in terms of sound quality, rear fill can be detremental unless you're running a 5.1 processor or something to that effect, which will temper how much the rear speakers will put out. if all you care about is playing it loud, then rear fill is very important. more drivers = more output.... my opinion, of course!
toneddie
toneddie
lodi, ca
MxRacerCam
michigan born
    May 14, 2026
michigan born
    May 14, 2026
