Xtant at 1ohm?
ottoguy
Basicly as the title says; can I run an Xtant amp at 1ohm? I want to put an Xtant amp with a 2ohm dual voice coil IDQ 10" sub, and the options are 4ohm and 1 ohm. The amp I'm looking at only puts out 125watts at 4ohms. I was liking the 250watts at 2ohms, but can't wire the sub to run at 2 ohms with two 2 ohm voice coils. I didn't see anything in the Xtant info about running at 1ohm, so I'm not sure if this will kill the amp?
im sure the class d amps do...is it class d......
Well it was on ebay. Apparently someone decided to buy it now, so I can't even bid on it. Anyway it was an Xtant 121M.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ih=018&item=280009741581&rd=1&sspagename=STRK%3AMEWA%3AIT&rd=1
Anyway, so any Class D amp should work at 1ohm? Also how do you know if its class D or not?
well the class d topology is used for amps that usually power subs. While most class d's are capable of running in 1 ohm operation some companies choose to modify the amp to only go down to 2 ohms like the memphis mc2000...if its ran down into 1 ohm it will go into protect, a quick mod can solve this, the 2500d uses the same board and it's stable below 1 ohm so a mod to the amp would allow for 1 ohm operation, causing it not to go into protect...iono just an example of a class d thats rated at 2 ohms...but to answer your question most class d amps are stable at 1 ohm.
ottoguy
ottoguy
Delaware
Big Nev
