Wut size box 4 L7 12"
TheSpeakerMan
Knockin Pics Of da Wall
I was gonna have my box made at 3.5 cubic ft. But i c on here every1 is having it around like 2.25/ 2.50. Do bigger boxes have more spl? Or more sq? Wut would be the perfect box size for mostly spl and enough sq to sound ok. It is a 06 12" L7. Only have 1. I listen to rap
if you look at the manual for this sub there are three suggested ported enclosure sizes:
Compact -- 1.75 + port
Street Bass -- 2.5 + port
SPL/ Deep Bass -- 3.25 + port
the SPL will give you the deepest bass but it is more of a one note wonder....i would suggest the Street Bass box. I have herd them all and this is the best sounding box by far.
Ported Solo-Barics incorporate massive slot loaded ports with ultra low air velocity for ground pounding street bass that will make your hair stand on end (if you have any left)! These are the enclosures of choice for outrageous street bass and high performance SPL contests.
The following chart shows three recommended ported enclosures for each Solo-Baric driver.
Compact has increased bass efficiency over a sealed enclosure, yet can still fit in tighter applications. It is the smallest design that will work well for each woofer. Although it is the smallest ported enclosure the output from 30 to 80 HZ will be considerably higher than that of a sealed box. This smallest vented design is for places where you can only give up the room normally taken up by two L7s in the normal small sealed boxes. The two other ported designs have proportionately more output in this region.
Street Bass is a medium sized enclosure that will kick out bass that can be heard for blocks away. And it does go LOW!
Finally, SPL / Deep Bass is a large enclosure that has it all. It is high efficiency and will deliver the output needed to win SPL contests, yet low frequencies go all the way down to the basement - with power that will shake the foundations! We’re talking truly awesome.
If space is not at a premium and you want to get the most from your Solo-Baric® L7, try one of these designs. You won’t be disappointed. Note: You must add the port volume to the volume of the box! See the cut sheets.
S12L7
1.75 cu.ft. + port
2.5x13.25" port, 22.5" long
Power Handling = 750W
2.5 cu.ft. + port
2.5x13.25" port, 16.5" long
3.25 cu.ft. + port
3x13.25" port, 14.5" long
Thnx corvette ure 1 of the nonstuck up ppl on here. Most ppl are stuck up pricks. I will prolley go with 2.75 cuz it is close to street bass but has a lil more spl then street bass. SOund good?
some1 is buildin for me. Wut are u tuning ures at? I was thinkin prolley 36-38 cuz team kicker said they start to shine above 35. And they dont start losing sq until around 36-38
TheSpeakerMan
TheSpeakerMan
Conway, AR
corvettecoop
