WTT Hifonics 2610D for smaller amp
Boomsday
My House
Downgrading a bit, looking to do a straight trade for an amp that does about 1500rms@1ohm +cash, or +box build (just 2.5cuft), works 100% the lights just do not glow blue anymore...Functionally its 10/10 Cosmetically its 8/10
specs
* RMS Power Output: 1 x 850 W @ 4 Ohms
* RMS Power Output: 1 x 1700 W @ 2 Ohms
* RMS Power Output: 1 x 2600 W @ 1 Ohm
* Slow Un-Mute Turn-On (soft start)
* Protection: DC, Speaker Short, Thermal, Overload
* Power Supply MOSFET
* Audio Output MOSFET
* Dampening Factor: >250
* Signal To Noise Ratio (A-weighted): >95dB
* Variable Input Level Control (unbalanced): 0.2V - 9V
* Input Level Control (balanced): 0.04V - 18V
* Input Impedance (un-balanced): 47k-Ohm
* Input Impedance (balanced): 20k-Ohm
* Power / Diagnostic L.E.D.
* Variable Low Pass Filter / 24dB: 35Hz - 250Hz
* Variable Subsonic Filter / 24dB: 15Hz - 35Hz
* Variable Bass EQ: 0dB - +10dB
* Phase Shift (0 - +180 degrees)
* Unbalanced Inputs (RCA)
* Balanced Inputs (DIN)
* Line Output (RCA)
* Speaker Terminals (molded): 12ga
* Power/Ground Terminals (molded): 0ga
* Remote Bass Module: HFR-3
* Parametric bass EQ with 45Hz bass boost and variable control from 0db to 10db
* Variable Low Pass, Subsonic Filter, Phase Shift and Level Control
* Balanced line input for MX accessories and line drivers
* Bass Remote included
* Built-In System Diagnostics protects from short circuits, over load, thermal overheat and DC Offset.
* Link & Sync™ feature allows the mono amps to be strapped or bridged via master/slave configuration
* Dimensions 17.72" x 2.52" x 9.45"
Have a fresh in box JBL bp1200.1! Benched at 1376 wts rms anywhere between 1 and 2 ohms!
vitveet@hotmail.com if interested! Could work out a deal with the enclosure also....Have a few build already too!
V.
dsc 1500?
I would +some cash on your end
How much to sell outright?
Cheap PM me
i like this amp sure could use it for a back up or for my other class hey you up for trades ??? :S
Yep need an amp that does 1500rms and an Enclosure
Have a fresh in box JBL bp1200.1! Benched at 1376 wts rms anywhere between 1 and 2 ohms!vitveet@hotmail.com if interested! Could work out a deal with the enclosure also....Have a few build already too!
V.
pm'ed
also one of the mountin feet has became broken and 2 more cracked (still usable) not sure how that happened from just sittin //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Yep, at the amplifiers. I get the same 14.7 volt reading when they cutoff too.
Pull it and test it at the battery post. Simple Power up test to verify if it powers up fine out of protect mode. if it does then Id be checking...
I have a Gemeni VII, Heucules VII, Pluto VII, and a Vulcan VII left out of a massive slew of VII and VIII series. They still work Excellent...
  • Locked
COMPLETED Hifonics Plato III
Yes, they are painted. The cover is very easy to take off and repaint to whatever color of choice to match the install.
Boomsday
Boomsday
My House
d77543020
    May 31, 2024
    May 24, 2024
