WTT Hifonics 2610D for smaller amp
Boomsday
Downgrading a bit, looking to do a straight trade for an amp that does about 1500rms@1ohm +cash, or +box build (just 2.5cuft), works 100% the lights just do not glow blue anymore...Functionally its 10/10 Cosmetically its 8/10
specs
* RMS Power Output: 1 x 850 W @ 4 Ohms
* RMS Power Output: 1 x 1700 W @ 2 Ohms
* RMS Power Output: 1 x 2600 W @ 1 Ohm
* Slow Un-Mute Turn-On (soft start)
* Protection: DC, Speaker Short, Thermal, Overload
* Power Supply MOSFET
* Audio Output MOSFET
* Dampening Factor: >250
* Signal To Noise Ratio (A-weighted): >95dB
* Variable Input Level Control (unbalanced): 0.2V - 9V
* Input Level Control (balanced): 0.04V - 18V
* Input Impedance (un-balanced): 47k-Ohm
* Input Impedance (balanced): 20k-Ohm
* Power / Diagnostic L.E.D.
* Variable Low Pass Filter / 24dB: 35Hz - 250Hz
* Variable Subsonic Filter / 24dB: 15Hz - 35Hz
* Variable Bass EQ: 0dB - +10dB
* Phase Shift (0 - +180 degrees)
* Unbalanced Inputs (RCA)
* Balanced Inputs (DIN)
* Line Output (RCA)
* Speaker Terminals (molded): 12ga
* Power/Ground Terminals (molded): 0ga
* Remote Bass Module: HFR-3
* Parametric bass EQ with 45Hz bass boost and variable control from 0db to 10db
* Variable Low Pass, Subsonic Filter, Phase Shift and Level Control
* Balanced line input for MX accessories and line drivers
* Bass Remote included
* Built-In System Diagnostics protects from short circuits, over load, thermal overheat and DC Offset.
* Link & Sync™ feature allows the mono amps to be strapped or bridged via master/slave configuration
* Dimensions 17.72" x 2.52" x 9.45"
dsc 1500?
I would +some cash on your end
How much to sell outright?
Cheap PM me
i like this amp sure could use it for a back up or for my other class hey you up for trades ??? :S
Yep need an amp that does 1500rms and an Enclosure
Have a fresh in box JBL bp1200.1! Benched at 1376 wts rms anywhere between 1 and 2 ohms!vitveet@hotmail.com if interested! Could work out a deal with the enclosure also....Have a few build already too!
V.
pm'ed
also one of the mountin feet has became broken and 2 more cracked (still usable) not sure how that happened from just sittin //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Boomsday
Boomsday
My House
d77543020
