Downgrading a bit, looking to do a straight trade for an amp that does about 1500rms@1ohm +cash, or +box build (just 2.5cuft), works 100% the lights just do not glow blue anymore...Functionally its 10/10 Cosmetically its 8/10
specs
* RMS Power Output: 1 x 850 W @ 4 Ohms
* RMS Power Output: 1 x 1700 W @ 2 Ohms
* RMS Power Output: 1 x 2600 W @ 1 Ohm
* Slow Un-Mute Turn-On (soft start)
* Protection: DC, Speaker Short, Thermal, Overload
* Power Supply MOSFET
* Audio Output MOSFET
* Dampening Factor: >250
* Signal To Noise Ratio (A-weighted): >95dB
* Variable Input Level Control (unbalanced): 0.2V - 9V
* Input Level Control (balanced): 0.04V - 18V
* Input Impedance (un-balanced): 47k-Ohm
* Input Impedance (balanced): 20k-Ohm
* Power / Diagnostic L.E.D.
* Variable Low Pass Filter / 24dB: 35Hz - 250Hz
* Variable Subsonic Filter / 24dB: 15Hz - 35Hz
* Variable Bass EQ: 0dB - +10dB
* Phase Shift (0 - +180 degrees)
* Unbalanced Inputs (RCA)
* Balanced Inputs (DIN)
* Line Output (RCA)
* Speaker Terminals (molded): 12ga
* Power/Ground Terminals (molded): 0ga
* Remote Bass Module: HFR-3
* Parametric bass EQ with 45Hz bass boost and variable control from 0db to 10db
* Variable Low Pass, Subsonic Filter, Phase Shift and Level Control
* Balanced line input for MX accessories and line drivers
* Bass Remote included
* Built-In System Diagnostics protects from short circuits, over load, thermal overheat and DC Offset.
* Link & Sync™ feature allows the mono amps to be strapped or bridged via master/slave configuration
* Dimensions 17.72" x 2.52" x 9.45"
specs
* Line Output (RCA)
