WTF!!! Voodoo 1600.1 vs DEI 1500d
I've installed a few of their amps, quite a bit of their wiring and capacitors.From what I have experienced, they're actually pretty decent.I'd take that amp over that directed any day, sadly that isn't saying much //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
hey mout whats up with the fusing they dont have any visable on the amplifier from the pics and another guy was saying this as well, do i need to fuse externally like 18 inches before in amp or something? the manual says 150A (external)
fuse roughly 18 - 24" from ur amp with a 150 amp fuse most high power amps dont have fuses on board. I'm running two batteries so i fuse about 18 " from my battery prolly a lil longer then i run my power wire to my amp .
Have a fuse under the hood, 18-24" from the battery, not the amp...
Actually whats normally reccomended is 18 - 24 under the hood if you run a single battery and then another 18 - 24 from the amp. This is for amps that require external fusing.
nissanrider06
VooDoo
nissanrider06
Eagan, MN
Shinobi
