Wouldn't 4 8s be louder than 1 15?
Why do you think that is? Why would 1 15 which is less cone area on the same power be louder? Just not enough box testing?
motorforce, excursion etc... Multiple subs dont add to the motorforce, its just constant for the same motor used. I've seen plenty of single 15s doing 150s musical but its rather hard with 8s unless its more of a limited bandwidth/more output style enclosure.
Makes sense. I'll quit dreamin and do 1 15! I'll definitely regret it if I don't take your advice! I know that... I bought a Skar... Lol
i hadnt decided what amp yet. but for a small amount of time was going to run on 2 apcl1500.1s strapped. I know they **** but it would just be temporary. Hopfully two more reliable 2ks strapped.
Or just a single 4k.
There has been a bit of controversy regarding strapping amps.
No need to complicate things if you don't have to. This is also a reason I would go with a single amp, single sub setup.
Less equipment to break and when/if it breaks, fewer things to diagnose.
Stolen from SMD
How to calculate cone area
Cone area = pi x (r x r)
pi = 3.14 r = radius of sub
One 8" = 50.27
One 10" = 78.54
One 12" = 113.1
One 15" = 176.71
One 18" = 254.47
Two 8" = 100.53
Two 10" = 157.08
Two 12" = 226.19
Two 15" = 353.43
Two 18" = 508.94
Three 8" = 150.8
Three 10" = 235.62
Three 12" = 339.29
Three 15" = 530.14
Three 18" = 763.41
Four 8" = 201.06
Four 10" = 314.16
Four 12" = 452.39
Four 15" = 706.86
Four 18" = 1017.87
Stolen from SMD
One 8" = 50.27
One 10" = 78.54
One 12" = 113.1
One 15" = 176.71
One 18" = 254.47
Two 8" = 100.53
Two 10" = 157.08
Two 12" = 226.19
Two 15" = 353.43
Two 18" = 508.94
Three 8" = 150.8
Three 10" = 235.62
Three 12" = 339.29
Three 15" = 530.14
Three 18" = 763.41
Four 8" = 201.06
Four 10" = 314.16
Four 12" = 452.39
Four 15" = 706.86
Four 18" = 1017.87
Can be found on google also...
https://www.bing.com/images/search?view=detailV2&ccid=X6DYBf1d&id=5F3528ED6B570A3671BFB05D74EF7C385D536014&thid=OIP.X6DYBf1dPqqxBDqZLqnCjgHaFw&mediaurl=http%3a%2f%2fwww.samadhilounge.com%2fesa%2fimages%2fTB%2fConeArea.jpg&exph=376&expw=484&q=subwoofer+cone+area+chart&simid=607989555218286574&selectedIndex=1&qpvt=subwoofer+cone+area+chart&ajaxhist=0
[quote name='dudeogo']Ive already done 1 15 before. 4 8s sounds interesting and more cone area. Plus if I like it I could just swap to SSA F8ls which I would buy in the first place if @denim could hook me up with a coupon <3[/QUOTE]
The F8L's will be back in stock soon. They are available for pre-order at the moment. :)
Yes, I have a difference, but my difference is HUGE. The difference can be so big, as if I had a sound system in about 150-200 dolars (with wires...
41
10K
I'm not sure if it was mentioned, but you can removed all bass absorbing material from the inside, such as carpet and cushioned seats. Also, do...
16
What are some of the louder, while still sounding good, 6.5" sets out there? Been looking at some of these higher powered Sky High Car Audio sets...
My subs unload at full tilt @ 28 hz, They are in 3.69 cubes net tuned to 34 hz. 4 - 8's. Big box and big power.
dudeogo
Actually a Potato
dudeogo
Springfield, Mo
denim
    Jun 15, 2024
    Jun 15, 2024
