would this sub/amp setup be good?
anthongy817
ok i just ordered a single re se 12". They're dual 4 ohm, and rated at 600w rms.
And im about to order a amp...i've been eyeing the diamond audio 600.1.
RMS Mono @ 4 Ohm: 300 x 1
RMS Mono @ 2 Ohm: 450 x 1
RMS Mono: 600 x 1 @ 1 Ohm
THD: 0.1%
Frequency Response: 20Hz- 250 Hz
Signal To Noise Ratio: >90dB
Crossovers: Low Pass, Subsonic
Dimensions 2.25" (h) x 8.5" (w) x 15.75" (l)
i'm debating over the diamond audio and the jl 500.1. I've read that the DA is highly underrated...but then JL has the big rep. What would ya'll suggest? And would those setup be compatible? Thanks!
anthongy817
anthongy817
Houston, TX
anthongy817
