How do i diagnose problem?
also, if it happens to be my 1000/1 thats the problem, i think im gonna get a different amp. i need about 1000-1500wrms at 3ohm or .75ohm. so i was thinking about checking out some old school hccas. any other suggestions?
I hope it doesnt come to this though. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif the 1000/1 cost me a pretty penny
you need to answer this question: how are you wired? in detail. for instance, i have 0 gauge with 300 anl fuse at battery.. which goes to distro blocc.. two 4 gauges go from my distro to my amps. the sub amp has no fuse between itself and the distro block. a 60-amp fuse is between the distro block and components amp. now when the fuse under my hood blew, i knew it had to be a short somewhere between the battery and the distro block. how did i know? becuz the component amps's fuse did not blow. i discovered the distro block was being pressed against the chassis (ground) under the back seat. i solved my problem. now u need to describe how your system is wired and where fuses are...
well how can i check for a short without ripping out the entire wire?
you might have to "un-install" stuff depending on wher it could short out. checc all the most possible places first.. for instance, if you have a distro block that is exposed with insulation on it.. or if you ghetto-rigged two seperate lengths of 2 gauge wire and twisted together or some ghetto shit like that.. checc the wires at places u think the wire might be being squished or something.. or possibly the insulation of the wire got penetrated somewhere.. u have to find the short. there is no tool that helps u find shorts i dont think.. unless u have extensive knowledge and know how to use a voltmeter to checc for continuity.
fatryan
Banned
fatryan
Southampton, Pa
fatryan
