Would this be a good setup?
Well, I ended up buying them, and I think they sound pretty good, I'm using a cheap SSL 100 watt rms amp, and they really hit, I'm going to get a different amp though.
So, everyone tells you not to get them and you get them anyway...
Would a Sony Xplod 1000 watt amp work good for these subs?
Sony Xplod amps are just as crappy as those subs.
Do some research before you spend your money, man. You stated you were only 16, with not a lot of money. To me, that would cause me to be sure I'm getting the best for my money, not some junk for cheap. With cheap gear, you get what you pay for. It sounds like crap, it won't last, and you'll likely start having problems with it way before you're ready to upgrade.
Trust me on this, I know. I built my first system at age 16, working part time at a steakhouse making maybe $200 a week. Most times $150 or less. I bought cheap gear right off and it blew up and I had to ride around with nothing because, instead of saving that cash for better stuff, I bought cheap stuff.
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
569
I had some 9500 series 12s by MTX that were some slamming subs!! Should have kept those along with those torpedo RE XXX 12s
15
968
I am doing an all JL audio instal on my new F250 SD . I'm using a Audio Control LC 5i Pro with a JL Audio XDM 700/5 and C3-650's in all 4 doors...
893
Id sit down and figure out exactly what all you will be installing for amperage consumption and add another 10-15% amperage useage on top of that...
21
tjmortenson
tjmortenson
Brainerd, MN
Why So Cereal?
    May 16, 2024
    May 16, 2024
