Would this amp sound good in my system
Wick
So ive given up on my other kicker amp and im getting a new one, i was wondering about the
ZX 700.5
# Amplifier Type 5 Channels
# RMS Power (4 ohms) 70 watts x 4 chan. + 210 watts x 1 chan.
# RMS Power (2 ohms) 85 watts x 4 chan. + 420 watts x 1 chan.
# RMS Power (1 ohm) Not Stable
# Bridged RMS Power 130 watts x 2 chan. + 420 watts x 1 chan. (at 2 ohms)
# Peak Power Output N/A
# Min. Impedance Unbridged 2 ohms
# Min. Impedance Bridged 4 ohms
# THD @ Rated RMS Power 1%
# Speaker Level Inputs Yes
# Amp Preamp Outputs Yes - 1 Pair
# Built-in Crossover Yes - LP/Full/HP
# High-Pass Crossover 50 - 200Hz
# Low-Pass Crossover 50 - 200Hz
# Subsonic Filter N/A
# Signal-to-Noise Ratio 95 dB
# Channel Separation N/A
# Bass Boost 0 - 18dB (subwoofer channel only)
# Bass/Gain Remote Yes (for subwoofer channel only)
# Fan Cooled N/A
# Fuse Rating 30A x 3
# Bass Boost Remote Control: 0 - 18dB at 40Hz
# CEA-2006 Compliant
# 24dB per octave Crossover: Active at 50Hz - 200Hz, High Pass, Low Pass, or Full-Pass selectable
# 4 gauge power/ground leads
# Dimensions: 20"L x 9 5/8"W x 2 1/8"H
my speakers are pretty basic pieces that sound good but cant handle high power very well
V-62HU
effective IMP.=4 ohms
R.D.C.=3.2 ohms
Resonant Freq.=70 Hz
Rated Power= 30 W
Max power 45 W
tweeters
R.D.C.=3.2 ohms
Rated Power= 10 W
Max power 20 W
my subwoofer is good
kicker S10L5
* Power Handling Watts Peak (RMS): 900 (450)
* Frequency Response: 24-100kHz
* Sensitivity: 86.5db
* Resonance Frequency: 33.3 Hz
* Solo-Baric L5 Subwoofer
* Nominal Impedance: Dual 2 ohm
* Total Q-Factor [Qts]: 0.403
* Equivalent Volume [Vas], ft3 (L): 1.53 (43.34)
* Outer Frame Dimension, in (cm): 10-11/16" (27.1)
* Mounting Depth, in (cm): 6" (15.2)
* Patented square woofer technology
* Ultra-rigid SoloKon with constant back bracing
* T-cut top plate for wider magnetic field, increased thermal efficiency
* Progressive-roll, poly-cotton spider
* Spring loaded terminals
* Voice-coil wire to 428 degrees F
* Rear foam gasket on stamped-steel basket with perimeter venting
do you think this would be a decent amp for my system and im looking to replace my speakers some day soon too, looking at making it an all kicker setup if possible
Wick
Wick
Temecula, CA
Powerbass1267
