Would I gain from a larger port?
7ender
Currently, i'm running a BTL in a 4 cube box at 33hz.
It's loud, but i'm wondering if I could gain some spl by putting in a larger port. It currently has a 6" flared aero (which equates to 28 square inches of port area, or a ratio of about 7" of port per cubic foot). I realize this probably isn't enough area, the box was originally made for a lower powered sub.
I'm also underpowering the BTL a bit, it's off 1600. Normally i'd just try this out to find out for myself, but it's going to require quite a bit of work as i'm going to have to fabricate a 7" aero.
So for those that have experience with similar setups/aero's- do you think i'd notice a gain upping the port area? A 7" aero will yeild about 39" of port and a ratio of ~9" per cube.
Yeah, I know. But unfortunately those pretty out of the question. No money for more power, no space for a bigger box, and I like my musical btl :p (yes, I know...).
go bigger, easiest and cheapest way to gain SPL, you can easily run 12sq.in. of port per cube and be very musical. id try that if i were you. shoot for about 40sq.in. ish
If you can't go any bigger, then a bigger port is just going to raise your tuning... unless you can make it significantly longer. But that, in turn, will eat up your internal airspace.
Hmm. Havent' needed any larger than 6" aero's before...any recommendation on how to make a 7"? I know you can use sonotube, but I don't want an 8" port //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif.
Bigger is not always better, but then again......
I run a Dd 9515 in 4.25 cubes with one 6" areo. With two 6" areos the sub was very sloppy and distorted very at about mid volume which was quite a bit lower in volume compared to a single 6".
Of now heres the kicker my brother same sub about the same size box but different vehical uses 2 6" areos and it works out great. His car is a honda CRV mine is an ext. cab. sonoma.
So you'll just have to try it. and see
in my testing, increasing port area will raise pressure level higher than properly tuning to your car's peak frequency.
I know this isn't for comp but to answer your curiosity, it would be better to increase your port area rather than increasing tuning.
For daily- it's advisable to do 12-16sqin per cube.
For comp - 28-32sqin per cube.
I forget the exact science behind it, but doesn't adding a little fiberglass insulation sort of have the same effect as increasing the volume of the box? Might be a possible solution if space is an issue. Unless I'm totally off-base, in which case disregard.
You're referring to polyfill...which is usually used in sealed boxes.
As for the 12-16 rule, I usually refer to that but iv'e found that for aero's I can get away with less (sometimes as little as half). Think i'll try a 7" port this time.
7ender
7ender
Los Angeles/San Diego
skmfkr
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
