would i be able to run a mono block class d on 2 subs thx
the a8000t is a mono amp but is not a class D is a class A/B...
that amp is 2ohm stable so you can run 2 4ohm svc subs or 2 2ohm dcv subs or 1 4ohm dvc sub... any of these configs in order to get the max power from the amp.
so if i have 2 dual 4ohm subs i can run both of the subs with this amp @ 2ohms???????
If i can do this then how do i need something speacial
thx for the help
so if i have 2 dual 4ohm subs i can run both of the subs with this amp @ 2ohms???????If i can do this then how do i need something speacial
thx for the help
You can do it, it is not a matter of "can I", but more of "will it work best"... And no, it will not. Two DVC 4 ohm drivers can NOT be wired toa final 2 ohm load, you can wire them to 1 or 4 or 16 ohms. 1 ohm will be too low of a load for your amplifier and it will SURELY fry, do NOT attempt a 1 ohm load on an Audiobahn that is not rated for it... 4 ohms is your only other option, but you will not get a high amount of power from the amp.
well i just bought a orion p12d4 (one) and i have that amp a Abahn a8000t and i fig i could just pay another hundred and get another p12d4 but i dont want to just upgrade everything i havent even installed it yet lol. and its my first system. but thx for the help anyways oh my sub is 500watts rms and 1000peak im probably goin to be over powering it by like 100 to 200watts but whatever
Doesn't sound like that Audiobahn amp even has enough power to adequately power two of those subs.
You're better off with one anyways.
oh sry i forgot to mention this is my older bros profile. and hes not really that much into it anymore he just lets me use his profile sry about that //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
playing with older bro's profile
Big-Cat
Registered User
Big-Cat
Jupiter, FL
Prowler573
