Working with a budget, box question
Lowjacker
1/1 of SexualConstipation
Due to a tight budget I'm using 2 10" Sony Xplod subs from wallyworld. I'm pushing them with an older model Kenwood Amp 2 Ohm bridged around 300W. What would be the best box for these subs. The instructions recommend a sealed enclosure but from everything I've read that provides the least amount of thump, which is what I'm looking for. Thiele/Small properties can be provided if needed.
Any help is appreciated.
Due to a tight budget I'm using 2 10" Sony Xplod subs from wallyworld. I'm pushing them with an older model Kenwood Amp 2 Ohm bridged around 300W. What would be the best box for these subs. The instructions recommend a sealed enclosure but from everything I've read that provides the least amount of thump, which is what I'm looking for. Thiele/Small properties can be provided if needed.Any help is appreciated.
from what i know about sony they really dont sound good in a ported box there more ment for a sealed box.
Here are the T/S specs:
Imp: 4 Ohm
d (inch): 8.5
Rdc: 3.5 Ohm
Fs: 29.9
Qts: .36
Qes: .38
Qms: 6.73
Vas(Cu. Ft.): 1.32
Hms(g): 145.6
Lvc (mH):1.8
Xmax (inch): .2
BL ™: 15.7
Recommended enclosure volume for 1 sub is .45 cubic feet
Recommended enclosure is sealed
I'm probably going to go with a sealed. But would adding a small port help or hinder? Not adding one to a sealed box. Just getting a vented box with a small port.
Lowjacker
Lowjacker
Eastern NC
Lowjacker
vegang
vegang
