Working on front stage with LOW BUDGET
ARK_SWAMP_RIDER
I have 2 JBL 10's powered by a fosgate 2 channel amp. I am wanting to improve SQ, so thought adding a component set would be the best way to achieve that. Here are the ones I was considering, mainly to match my subs:
http://www.sonicelectronix.com/item_7432_--+OVERSTOCK+CLOSEOUT-+--+JBL+GTO507C.html
I would probably also add this:
http://www.crutchfield.com/App/Product/Item/Main.aspx?g=762&i=237XT52&search=237xt&tp=2809
This will be ran off of the head unit. How does this setup sound? I am on a budget of about $100, have considered an amp but want to try it off the head unit first. Is there anything better for the price? Thanks.
I am going to look at a kicker 100.2 or 150.2 to power them. I am new, and my factory speakers sound good to me, BECAUSE I have never heard anything better. For that reason, I think running them off the head unit will be fine. If I do not like it, I will get the amp later, but that is a consideration. Thanks a lot, anyone else?
Yep, as all the others have said, PG RSD's. $87.00 SHIPPED from Ebay. Mine will be here Monday. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Yes, the RSd's will make love to your ears if you install and power then correctly. Deaden your doors, if not seal and deaded them. The RSd's love power according to all the reviews.... give them a clean 2x120-150w rms to get the most out of them.
Also look for deals on the Pioneer TS-C160R, as they can be had for around the $120 range. They'll do just fine off of 2x50-120w rms.
OK, system has changed. I am planning to run the PG RSD's, I guess 5 1/4 inch ones. I will power this with a Cerwin Vega EXL-400.4 amp. Does this sound like a good combo for less than $200? Thanks a lot.
Umm, get a 2 ch amp, would be cheaper, and have more power.. (Not sure if you can bridge both channles on that amp.)
ARK_SWAMP_RIDER
ARK_SWAMP_RIDER
Arkansas
ARK_SWAMP_RIDER
