Wood glue or liquid nails?
Seems like quite a bit of people are debating between the two. I wish someone can do a finite element analysis to figure out which is the stronger of the two. My guess would be that wood glue is stronger, but I don't have any "scientific evidence" so to speak to prove that one is superior over another.
to tell you the truth, as long as you use glue, screws or brads, and a well braced enclosure. there is realy no need to debate whats better.
if you realy want a realy strong box then seal it with polyester resin as well.
Wood Glue ftw, chemical bondage and then some silicone to ensure the seal! //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I found a good website about different types of glues.
http://www.trainweb.org/girr/tips/tips5/adhesive_tips.html#latex
Here's what I found if your too lazy to move your finger.
Paper and Wood Adhesives
Wood is an important material in model railroad construction, both in the structure of a layout itself and in buildings and rolling stock. Paper and cardboard are also common materials.
Probably the safest and most common adhesive used in modeling is ordinary white glue. The most common adhesives in this category are called polyvinyl acetates. This is a water based adhesive that adheres well to paper and wood. It is not particularly strong and it is not tolerant to water, but it is cheap and safe. The material dries milky colored. White glue can be diluted with water and sprayed over texturing materials to hold them in place.
Yellow carpenters glue, sometimes called aliphatic resin, is a better choice to bond wood. This adhesive forms a strong bond that is somewhat tolerant of water. This adhesive dries in a somewhat yellow color. Properly made joints are often stronger than the wood that they attach to.
There are more advanced wood adhesives that are waterproof and in general they are stronger that yellow carpenters glue. Some brands names are Liquid Nails and TiteBond II. These adhesives are suitable for use in outdoor wood structures, even in wet environments.
Latex Based Adhesives
Latex is used as a base for some types of adhesives. These are usually fairly strong and reasonably waterproof. Liquid Nails falls in this class. This adhesive is not the strongest of the bunch, but it is usually strong enough and will adhere to wood, metal, glass and masonry and it takes paint very well. Liquid Nails comes in many formulations for specific jobs, but the most applicable is LN-901 exterior grade adhesive. Liquid Nails is available in squeeze tubes or caulking gun tubes. I find that the caulking gun tube is inexpensive (less than $3) and effective as the adhesive is fairly easy to clear from the applicator tip after it has set up. Simply ram the tip out with a metal rod or drill bit and then squirt out the hardened adhesive until fresh adhesive comes out.
A better combination latex and silicone based adhesive is Lexel. Lexel also comes in squeeze tubes and caulking gun tubes but it costs about 3 times as much as Liquid Nails. However, it is stronger, more flexible and has better adhesive strength than Liquid Nails. Lexel comes in white and clear formulations. Lexel also works well in a caulking gun tube. If the tube tip is plugged with a large toothpick or a metal rod, the adhesive will not set up in the tip and the tip is easy to clear. Unlike other silicone adhesives, Lexel will take paint well after it is allowed to set for two days. Lexel adheres to just about anything.
There is also a Lexel formulation called Set N' Stone available that is intended for use with masonry. This is a new product and is not yet widely available.
[Top]
I'd still choose wood glue over liquid nails though, I don't know if this person has credible information, but I'd thought I'd throw that in to stir debate.
lol... You've got to be kidding me... Man, from what I've seen on here... It makes no difference... Ur box will be held together, just ur preference... RawDogJ, who won 4th in the world for DB dragging, uses liquid nails... I myself, who am nobody special, use liquid nails, but alot of other people on here use wood glue... I say you flip a quarter, that's about the only way you'll get everything settled...
I use Titebond II thanks to Moe Lester telling me about it.
Liquid Nails did make some fairly strong bonds that would cause the wood to break before the joint, but I have more confidence in the Titebond II and it's easier to clean, sand, and apply. Ends up costing a bit more unless you build enough to buy the gallon, but well worth it.
Titebond II + finish nailer = efficient and extremely sturdy boxes.
JL12W7INAGS300
CA's Most Hated
JL12W7INAGS300
Oklahoma City
trevor87
