Wiring???
//content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif :furious: ****it, i feel really stupid now, ima go back and double check just to make sure thanks alot
alright, what about speakers, cus i cant easily pull them out of where i have them, i had to custom cut the metal in my panels, and then mount them to 1" thick MDF to get the mounting depth thick enough, so i dont want to pull them out... any easy ways to tell?? it would be easier for me to pull the deck out and switch the wires there if i had to
well first check the subs.....after that turn your amp off......fade the music all the way to say the front.....then bal it all the way to the left.....if u have good bass and everything good....then switch all the way to the right.....if u still have good bass....cool.....then switch it back tot he middle....if u have crappy bass.....most likly one of them is out of phase..... same w/ the rear....just switch the pos w/ the neg which ever way is easiest for u....might take a little time if your fron speakers are in diff phase than your rear.....easist way would be to make sure everything is wired properly tho.....
i doubt it, i have a cheapy pioneer deh-1400, with infinity 552i's.... ill go check my sub in a few minutes, but the speakers ill prolly just have to pull out and double check... argh..//content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif
nope, all the wiring is done by me, this car is... dont laugh... its my first car... an 86 chevey chevette which only came with one speaker in the center of the dashboard, so mounted them here...
http://www.chevettes.com/showimage.php?section=na&page=23&chev=810
so its all my own wiring, im realizing that im just gonna have to pull em out, its only front speakers tho, i havent put in back ones yet
ya, i prolly wont, itll be a waste of time and money, mainly cus ill have to do it all custom and cut the holes myself, and this is only a temp. car, its my first one.. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif im a young'n 16 lol
I'm having issues color coordinating my wire colors on my 05 Buick lacrosse. They have multiple colors that are the same. I'm trying to put in an...
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
425
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
494
552
492
motoxstud
motoxstud
Arizona
motoxstud
    Jun 1, 2024
    May 31, 2024
