I have (2) Lanzar MAX12D's dual voice coil subs @ 4 ohms per coil with a max wattage of 1000 watts @ 2 ohms and 500 watts @ 4 ohms each sub.(4ohm nom. impedance). I plan to connect them to a Lanzar HTG 244 Heritage amp. 2x250W RMS at 4 OHMS. 2x500W Max at 4 OHMS
1x1000W Max at 4 OHMS Bridged. 2x420W RMS at 2 OHMS and 2 Ohm Stereo Stable Operation Bridgeable at 4 Ohms
THD: 90dB
Channel Separation: >65dB
Stereo, Bridge and Tri-Mode System Application Compatible
One of two questions is: how do I wire the subs and the amp to get the most out of them. I saw some diagrams on one of the posts about the Fosgates but it was unclear to me because I only saw one positive and negative lead running from the amp to the subs. Was it a one-channel amp? If it was a two-channel amp, why wasn't leads running from the amp to one sub and then the other? Maybe I need to be explained about how the diagrams are set up. Any help?! I need a diagram that clearly shows how to wire subs with a two-channel amp. My other question is: what are the dimensions for a sealed enclosure per MAX12D. I have to have a sealed enclosure because I don't have much room in the trunk. I have a convertible and my trunk dimensions are: 14"(H)x10"(D)x38"(W), which is pretty small. Do you recommend ports, and if so, what length, diameter, and position(top, side,front). Any help would be appreciated.
THD: 90dB
