wiring speakers and amp
yungstarter
im new to aftermarket installs and self installs
is each channel on a 4 channel amp an individual load? so if i have a 4 channel amp and 4 4 ohm speakers the total load will be 4 ohms a channel or 1 ohm on the entire amp? Im using the rockford fosgate p400-4 which is NOT 1 ohm stable. For speakers im running 4 SPR-17C's ALpine type R 6-1/2 coaxials
Each channel combined with speaker is in series thus 4 ohm load per channel.
However if i wire 2 speakers into one channel that is in parellel and will lower the load?
Am i figuring this basic wiring right?
QQ should paid more attention in physics
4 channel is like having 4 separate amps. Each channel handles it's own load, so you would have 4 channels running at 4 ohms each.
If you wire 2 speakers into one channel it will change the load on the amp, depending on how you wire them it could go up or down. At your skill level, I recommend you NOT do this.
ok thanks i wasn't planning on it i'm just building my system and wasn't sure if it was in series or parallel with the amplifier.
that answered my question thanks
well when your talking about regular speakers and a 4 channel amp you shouldn't have to worry about series or parallel because you should only have 1 speaker connected per channel...
yeah, i just didn't get each channel acted as an individual amp before. I was thinking it was the total load of all the channels on the amp So obviously none of my math and connections i was thinking of worked out. I just recently decided to start doing self installs and learning so sorry if i ask some dumb questions.
yungstarter
yungstarter
California
yungstarter
