how do they sound? Did you get the DVC subs or single voice coil subs? I'm not sure how to wire the DVC. Inside the box I am thinking of wiring each speaker in parallel and from the amp to the box in series. What do you think? any good?
if you are wiring 2 4ohm dvc subs you can eithr wire them at 1 or 4ohms. at one ohm you wire all the negatives together and for 4 ohms wire one negative from one sub to the other and one positeve to the positive to the next sub with the remaining vc on each sub go poitive to negative its kinda simple if ya see a pic if you need one go to rockfordfosgate.com and go to rf tech then find an answer then look at how to wire two subs. they will make you go through some shit but you shoul be able to find it
