wiring scheme
loner7757
i am sbout to buy 2 kicker comp vr 15, the only problem is they are dual 2 ohm voice coils on each is there a good wiring scheme i can use, i figured an eight ohm load is the best i can get, i am running them off a punch 500a2 . also has anyone ever actually listened to a set of these?
if they are 2ohm dvc yuo can wire them at 2 ohms or like .5 ohms to wire them at 2 ohms wire the first positve to the first positive of the next sub and the same with the negative and the other voice coil of the sub go positive to negative on each sub this will give ya a 2 ohm load. hope that helps. if not tough shit
loner7757
loner7757
meriden ct
geonn
Giles
    Sep 4, 2026
Giles
    Sep 4, 2026
