wiring options that were not answered in stiky
so with all 6 dual 4 wired how would I achieve the 1.34 ohms? would I wire each sub to 2 ohms then wire all three together to what ohm load then do the same to the other 3 then wire the 2 sets of three to one load?
read post 2
a pair of dual 4 ohm subs wire into a 1 or 4 ohm load, wire them to a 4 ohm load, so then you have three 4 ohm loads. Those three loads will wire series into 1.3 ohms
diagram? lol sry I think I get what your saying. wire each sub to 2 ohms put two subs together for a 4 ohm load. then wire the three sets of subs together down to 1.34 ohms.
nvm I got it. I'll use the RF wiring wizard lol i can get the two subs to 4 ohms then I get just putting all 3 pos+ terminals together and the same with the neg. that works ok thanks!
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
163
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
223
432
388
lovindabass
Banned
lovindabass
brooks,Ga
Stalin-ohaulic
    May 20, 2024
    May 20, 2024
