Wiring Mono Block Parallel
XplodX
I have posted this question before but i still dont get how to wire my Xplod Mobile ES Xm-6001GXD mono block 1000watt amp Parallel to my 2 single voice coil 4 ohm 12's.
The reason is that even though this is a mono amp their are 2 sets of positive and negative terminals on the amp. any help would be greatly appriciated.//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
im thinking youd just use the positive terminal from the one side and the negative from the other, could be wrong but thats how parallel usually works.
and i have no clue why youd have two sets of terminals on a mono?
Often times monoblock amps have more than one terminal if you don't plan to wire your subs in parallel. If you don't use the other terminals, I don't think, it has any affect on the output power of the amp. If it's a 1000 watt d class amp, which has 4 terminals (2 positive, 2 negative) and just use two terminals, 1000 watts is still going just to that one channel. If you have two 4 ohm SVC subs, and you'd like a 2ohm load on the amp, You'd take a positive from the amp, to the positive of one sub. A negative from the amp to the negative terminal of the first sub again. And then, you take the + from the first sub terminal, and go to the + of the second sub terminal. The - from the first sub terminal to the - of the second sub terminal. If I'm wrong about the amp thing, feel free to pipe in.
the second set of terminals on the amp is for wiring convenience. it does not matter if you use it or not. just hook one set of terminals on the amp to the first sub (plus to plus and neg to neg) and then do the same for the other set of terminals and the second sub. this will wire the two subs in parallel because the two sets of terminals on the amp are combined inside the amp.
Lets get this right.
I think Mark_ab is right, So all + & - need to go together
FROM THE AMP
TO THE FIRST SUB
FROM THE FIRST SUB
TO THE SECOND SUB
But I don't think you need to switch + & - around. As this would send it out of phase wouldn't it????
Please correct me if I am wrong
Mark is correct JBL does the same thing they outputs are connected internally so though you really only have one channel it makes it easier to connect two or more speakers.
Mike
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
326
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
407
503
455
XplodX
XplodX
Mendocino,CA
53kicker
    May 24, 2024
    May 23, 2024
