wiring kit
  • 2
Just run the rear doors off the head unit and get a set of components for the front instead to use on the 4 channel. If you want a subwoofer down...
666
You just cut two pieces the same length, and connect the negative together at each end, and the positive wire the same way, basically connecting...
38
Deff need to lnow what subs.. Make and Model# would help quite a bit. What amplifier will you be using?
116
365
nswartley
Down and out...
nswartley
(Near) San Jose, CA
97dakota
    May 18, 2024
    May 16, 2024
