wiring help
Pyle PLMRMP3B 4 Channel 800 Watt Waterproof Micro Marine Amplifier , Infinity Reference 612m 6.5-Inch 225-Watt High-Performance 2-Way Marine Loudspeaker (Pair)
You said you'll be running four 6.5's then in the next sentence you said you want to run 6. I'm confused.
Regardless.
Like everything pyle, that amp is ridiculously over-rated.
With a 10A fuse there's no way the power output can be much more than 100w rms -- total. That would be ~25x4 at 2 ohms or probably ~20x4 at 4 ohms.
It will run 4 speakers about as well as the average head unit.
This is about twice as powerful: https://www.sonicelectronix.com/item_71986_Clarion-XC1410.html
Even more power. Still very small. https://www.amazon.com/Soundstream-SM4-1000D-Channel-Stealth-Amplifier/dp/B017VCX0TW
If you were planning to add two more speakers for 6 total the extra power would be helpful. You could run 4 on 2 channels wired parallel for 2 ohms getting 50-60w rms each (assuming the amp's a little over-rated). The other pair would be getting 80-90 (on paper, of course).
cmarinew
cmarinew
tx
n2audio
