Wiring HELP!
papaslack
I am looking to wire my 2 channel amp into the max load for two 6.5 speakers.
Rockford Fosgate 2.6x
(4 ohms)30W x 2 Output Power
(2 ohms)60W x 2 Output Power Bridged
(Mono)120W x 1 Distortion Max
(4 ohms)0.08% Frequency Response
(+/- 0.5dB)20Hz - 20kHz Signal to Noise
(A-weighted)>100dB Input Sensitivity (+0dB gain overlap)350mV - 6V (low level input)
1V - 13V (high level input) Bridgeable Yes Punch EQ
(45 Hz / 20 kHz)No Pass-Thru No Xcard Qty 1 Length 7-11/32 in
(18.7 cm) Width 8-5/16 in
(21.1 cm) Height 2 in
I believe i should wire them in series like the below link to drop it to 2ohm. Is this correct?
http://www.avsforum.com/photopost/data/2356991/0/0a/0ad54053_sp_wiring_series.gif
papaslack
papaslack
St. Louis
papaslack
vegang
vegang
