wiring help
run them all parallel. Put all the positives together and all the negatives together. 1 dual 4 wired in parallel gives you 2 ohms. You have 2 dual 4's, so after you have wired them seperately you have "a dual 2 ohm subwoofer" With this, you hook the positives together, and the negatives together, giving you a final resistance of 1 ohm.
i will need a diagram lol i got lost if anyone finds one plz post it
so i have to take one pos and 1 neg wire from a sub and connect it to the other?
Did you not understand the picture? It's got to be the easiest thing to understand...
Connect all positive wires together and all negative wires together. Hook it up to the positive and negative terminals on the amp.
ok thanks lol i got that
your R's should have come with jumpers for the voice coils. the jumpers emiminate the need to run a wire to connect both ( + ) on one woofer.
run a wire from one ( + ) on one woofer to the ( + ) on the other woofer and then run another wire from that terminal to the amp.
same for the neg.
AlpineUser
Bumpin
AlpineUser
St. Charles Mo
Ingleside
