Wiring Help.
Zacmc212
FL
I installed a LOC and found the wiring guide for the stock radio, and was wondering which one should i split for the Remote wire...
this is in a 2002 ranger...
12V yellow ignition harness(IH)
Ignition red/lt. blue IH
Accessory lt. green/purple IH
2nd Accessory black/lt.green IH
Power Lock pink/yellow driver door harness or PKP
Power Unlock pink/lt.green *4 driver door harness or PKP
Lock Motor pink/black driver door harness
Unlock Motor red/orange driver door harness
Disarm Defeat pink/orange passenger kick panel
Parking Lights brown headlight switch or GEM *1
Headlights red/yellow headlight switch
Door Trigger *2 GEM *1
Dome Supervision use door trigger
Tach tan/yellow instrument cluster or PCM *3
Speed Sense grey/black GEM *1
Brake Wire lt.green brake pedal switch
Horn Trigger yellow/lt.green steering column
LF Window Up/Dn wht/blk-red driver window motor
RF Window Up/Dn wht/yel-tan/lt. blu driver door harnessor PKP
Radio 12V lt. green/purple radio
Radio Ground black radio
Radio Switch yellow/black radio
Radio Illuminate lt. blue/red radio
LF Speaker org/lt grn-lt.blu/wht radio
RF Speaker wht/lt.grn-grn/org radio
LR Speaker gry/lt. blu-tan/yel radio
RR Speaker org/red-brn/pink radio
Also for some reason the radio is not turning on with the car, any ideas? everything is the same as before except the 4 wires that were split for the LOC.
thanks.
I used the "Radio 12V lt. green/purple radio" for the remote, and it gives the amp power, but it doesnt turn off with the car. Is this a big deal? because it is only drawing enough power to light up the green "on" LED right?
I will try the other wire tomarrow, i completely forgot to try the recomended "'Radio Switch yellow/black radio' " and my friend has already left.
no, its drawing more power than just lighting up the LED.use the yellow/black wire and you'll be fine
Think it will be ok over night? //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
No, your battery will be dead in the morning. (Yes, I'm serious)
He went to work a 430 and it started when he left (11ish) so thats good. I just called him and told me to take out the power and wrap it in elec tape untill toamrrow, so i should be fine. I hope that yellow/blk wire works for remote cause a ranger forum told me to use a different one and it didnt work at all.
Thanks
Zacmc212
Zacmc212
FL
Zacmc212
