Wiring help needed...
defensa24
PT Cruizer
Sup guys...
So I finally got my system up and running and it sounds good...(Not loud tho)
I have a pair of 10' subs (SPX...? I dont know how many watts) hooked up to a cheap walmart amp (200Watts...) The headunit is a Dual Stereo 200 Watts(from walmart yes) I wanna know if I hooked it up right? It sounds ok and maybe thats all Ima get out of it but Im curious to see if I can crank em up even higher if I wire them differently...Any comments? Help? Heres some pics of the wiring diagram and actual photos of my setup...
Okay after I am done laughing ill help....................................................OKay done you need to turn your bass boost off and set your gains. If you don't know how to do that search the forum for the article.
nice thowback //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
not so nice subs //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Sup guys...So I finally got my system up and running and it sounds good...(Not loud tho)
I think you mean 10" (in) subs not 10' (ft) subs... LOL //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Easy.... not everyone has good gear. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
The amp says 4-8 Ohms stable...And yes it has one voice coil...
Well since you have what I would suspect as being 4 Ohm SVC woofers and an amp that is only 4 Ohm stable, you are pretty much limited on wiring. You can only run them in stereo. If you amp supported a 2 Ohm load, you could bridge them and you would see an increase in output.
You also have a small sealed box, which is good for sound quality, but is hard to get loud. A ported box would have been much easier to get loud, but at the expense of sound quality. You basicaly have a setup that should be expected to have more quality than quantity. If you care more about quantity than quality, then you should look for a ported box.
EDIT: Here is a link to your woofers specs
defensa24
PT Cruizer
defensa24
Asheboro, NC
loopkiller
Mike Mccabe
