Wiring harness and temote-run on install help
  • 2
Gauntlet
bulletproof
edit: topic should read remote turn on....slightly drunk after watching the buckeyes //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I've got an 89 cutlass ciera, and I just bought a Pioneer DEHP8400MP. The wiring harness for my car does not have a remote turn on wire. I was told that GM combines the remote turn on with the power antenna. Should I simply connect the remote turn on wire from the head unit to the power antenna wire from the GM wiring harness?
thanks
The remote turn on is meant to go to an external amplifier. If you don't have an amp then just tape it off so it doesn't touch anything metal and possibly fry your HU.
See, that's what I thought. I always assumed that the remote turn on was used so that another piece of equipment (amp, radar detector, etc) would always turn on and off along with the head unit. But I asked the question at another forum, and someone said that if the remote turn on was left unconnected and taped off, then the head unit would never be able to power on. Now i'm just confused.
The wires that power the HU are a constant 12V line that keeps the clock set on time and saves your settings. A 12V accessory switch is run off the ignition to switch on everything when the key is set to either the accessory position or when the engine is running. There can also be an illumination wire going to the HU but it is not necessary.
All other wires are for speakers or to turn on amp(s). Remote turn-on means remotely turning on amps, not the actual HU in the dash.
Your image doesn't really show anything. That could be 3 different head units for all we know, but I think it's 2 different add-ons. It sounds...
907
So is the radio harness spliced direct to the OEM harness? There is no adapter harness?
12
If the plug matches, you just need to match the wires up. I re-made the harness for my audison amp, and the hardest part was getting the speaker...
Based off GM pickups of the same year (and that was GM), It SHOULD just be for the vehicle sounds that play through your stereo, such as the door...
Gauntlet
bulletproof
Gauntlet
Cleveland, Ohio
Heresy
Doxquzme
    Apr 28, 2024
Doxquzme
    Apr 28, 2024
Latest topics
