Wiring components in parallel??
  • 2
skyline
I have a 2 channel Signat amp (2x60watt RMS @ 4ohm) that I want to use to power my components (4ohm) and sub (4ohm DVC). The amp is 2 ohm stable.
What do you guys think of the quality of Signat??
I plan to wire the components in parallel, placing a 2 ohm load on the amp...is this feasible?
Why don't you see many people doing this?
I will also wire the sub in parallel. I'm not after a powerful system, just something that sounds good!
Thanks //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i'm sorry to say this, but you are going to need another amp. the reason people dont do that is because they loose fade and balance options. it would just make more sense to either run the amp bridged to the sub and the comps off the HU, or get another amp for the sub.
Deff need to lnow what subs.. Make and Model# would help quite a bit. What amplifier will you be using?
75
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
358
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
351
Box rise, more accurately, impedance rise, is the reactive load changes the woofer exhibits at different frequencies and it will happen, it's...
4
659
skyline
skyline
Australia
skyline
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
