Wiring an amp
Take a look at the firewall from the engine compartment. Sometimes there are existing holes that are plugged with a plastic seal for options that may not be installed. Sometimes you can squeeze a wire through an existing wire harness or speedo cable hole. If you have to drill, be sure to make the hole big enough to put a grommet or strain relief in too.
View attachment 26531080This is what I use if a soft rubber grommet is available in the firewall. It has a sharp, hollow tapered point and the whole thing is hollow through the handle. So all you have to do is poke it through the grommet and slide your wire through the tool.
Wolfs24
Wolfs24
Ozark, MO
guest
vegang
vegang
