Amp shuts off at mid volumes
Lance79
Ok so im a little savvy with this stuff but definitely not an expert. I've got an 05 tacoma just installed a bigger alternator (130 amp) im running 2 10" polk dxi dvc's with a 1000 watt 2 channel alpine amp. When I crank the volume up to around 25 the bass hits nice, but it will shut off after about 3-4 mins of continued use. My bass on my HU is at 0. When the amp enters protect mode sometimes it wont come back on for hours at a time. What is my problem? My connections are all solid, aswell as my ground.
I know you said your ground is good but I had a similar problem and I thought my ground was fine also. But my friend persuaded me to try a new ground and bam! The amp worked great after that.
I havent checked my voltage drops, but ill try that and get back to you as soon as i can. My amp wiring kit is pretty bottom of the line 8ga ground, and 8ga power with like a 16 gauge rem. Idk if buying a larger amp wiring kit would solve my problem or not if so let me know.
Lance79
Lance79
Aubrey, TX
guest
michigan born
    May 14, 2026
michigan born
    May 14, 2026
