wiring a toggle switch
Here's a simple diagram for what you would need. You can mount the toggle switch anywhere you want. You can get the power from your cigarete lighter receptacle. If the toggle switch has 3 pins, just make sure that one of the wires is connected to the middle one. Good luck.
-David
My toggle switch has only to prongs on it and all i basically did was hooked one up to my power source and the other to what i was running it to. It doesn't matter which one is + or-.
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
407
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
483
542
484
brooksi
brooksi
chippewa falls, wi
djjdnap
    May 31, 2024
    May 24, 2024
