Wiring 6x9's to amp while using an LOC for sub install.
Need help with another install question. Currently I'm usin a line output converter for a signal to my amp which is powering a 10" sub. I upgraded my rear 6x9s but now I want to connect them to a amp. Any ideas on how I should go about wiring them as I am using the rear speakers for my LOC? Should I just get a four channel LOC and connect the new amp that way? Any help or ideas you have are greatly appreciated.
Thanks
James
Need help with another install question. Currently I'm usin a line output converter for a signal to my amp which is powering a 10" sub. I upgraded my rear 6x9s but now I want to connect them to a amp. Any ideas on how I should go about wiring them as I am using the rear speakers for my LOC? Should I just get a four channel LOC and connect the new amp that way? Any help or ideas you have are greatly appreciated. Thanks
James
this would be the best option if you dont have an aftermarket deck installed. I would upgrade all the interiors at once instead of just the rears, it wont sound balanced.
Yea, you're probably right. My next step is to upgrade the 4x6s in front and then look at getting an amp for either just the 6x9s or for all four speakers. Just trying to figure out what kind of wattage I'm going to need for this amp. Thanks for your input.
Jberreth007
Jberreth007
Hastings, MN
Jberreth007
