Wiring 3 Subs to 1 ohm?
528hz
Everything'sMiscellaneous
I'm going to be getting 3 new subs, and I want to run them @ 1 ohm. I understand I need 1.5 or 6 DVC subs which are really hard to come by. So I have a few perdicaments.
I could get three 2 DVC subs and get a 1.33 ohm load or I could get three 4 DVC subs and have a 0.67 ohm load. Would it be better to be slightly over or slightly under on the load? They will be in a sealed box by the way.
Could I run different impedence subs to get a 1 ohm load (i.e. TWO 2 DVC subs and ONE 1 DVC)?
no mixing impedences..but if u do 3 and go with the.667 final load, cuz make the box a tad bigger to boost imp rise and youll be fine.
I would definitely go with the 1.33 route. W/o even knowing what amp - the power output between 1.3 and 1.0 would be so minimal it's not worth messing with. And trying to compensate for impedance with box volume is a shot in the dark at best.
I don't understand why people insist on risking their amps by running them at less than intended impedance for little, if any, gain.
528hz
528hz
In the Space between Space in NM
helotaxi
